Headlights
Headlights
Is there any advantage to swapping from phase 2 to phase 3 headlights other than looks plus what is needed to swap over besides the headlights
You should also swap to a twin optic stalk or modify your original stock, i think that the Ph3 lights have better light output
Ok will they just plug in Besides that what bulbs are in the p3 headlights
They are a direct replacement for Ph2 lights, and they take H7 bulbs
the only thing you'll want to keep from your ph2 lights will be the adjusters on the back, they should just twist off the ph2 lights, then twist back on to the ph3's, only cos Peugeot changed the connectors between phases.
(06-11-2012, 10:13 PM)WiNgNuTz Wrote: the only thing you'll want to keep from your ph2 lights will be the adjusters on the back, they should just twist off the ph2 lights, then twist back on to the ph3's, only cos Peugeot changed the connectors between phases.
They can be a bit of a faf to clip back in this way. What I did was clip of the electrical gubbins from the back of the motor and swap this bit over instead.
HDi Cabby Project Click
How do you mean ??
(08-11-2012, 11:16 PM)Willo Wrote: How do you mean ??
Its easier to explain if you have one to hand, drop me a pm later to remind me and I'll stick some pics up
Ok will do thanks
i unclipped the adjusters and plugged them in the phase 3 ones.
Light output is far greater and make the front look way younger lol
