welding the wastegate ?
hi just wandering what welding the wastegate would do to my d turbo, (pro's cons) thanks.
Pro's -
Booost,
Cons -
Lack of control of said boost.
Lol I'm also interested in the information here.
On the 306 waiting list.
Basically as above lol, mine is welded shut, if its a standard turbo don't bother IMO, welded gates need to be controlled by the amount of fuel as there is no wastegate to do that if you weld it up
Team Doesn't own a 306
In reality you will make more power with a welded gate, but its a horrendously inefficient way of producing more power, completely the wrong way to go about turbocharger tuning, but its free, and it works Big Grin its just in the XUD applications the engines/turbos are normally strong enough to withstand the abuse/heat caused by this so most people just drash on..
I am wondering about this for the future setup of 11mm pump and TD04L-19t hybrid, Although im worried about spacing issues once its got a bigger inlet housing than the 13t and 15g and then will have a actuator on. i am also wondering what the turbo would be boosting with a welded gate and biggish pump
Im currently ruinning TD04 with welded gate and think the 9mm may have some more to go yet and runnin 30psi atm
CJ
[Image: J5hxCcC.jpg]
I'm running a welded gate K04. It's ok so far, but I know it's not going to last at 30psi so I'll be building another with a wastegate on.
Stage 2 XUD Sedan
Just done mine Smile as the w/g was creeping !
  T2 wastegate arm AdamInNi 4 3,332 02-09-2014, 11:02 AM
Last Post: Dave
  welded wastegate help daveylennon93 16 9,101 31-07-2014, 04:44 PM
Last Post: Dum-Dum
  T2 wastegate pbell283 20 11,762 06-06-2014, 09:59 AM
Last Post: toseland
