15-10-2012, 08:33 PM
Ive set me steering column/ wheel as low as it will go. Does anyone know if i can lower it another 10mm(ish). Or just any lower at all?
Thanks
Ian
Thanks
Ian
![[Image: sig002_zpscb892e18.jpg]](http://i205.photobucket.com/albums/bb46/Silent_Rider-TP/car/sig002_zpscb892e18.jpg)
Steering column
Thanks Ian ![]()
15-10-2012, 10:05 PM
Might be able to get some longer bolts and spacers to replace the ones holding it to the framework thats welded to the body but how good this will be for the UJ is another question. And it might foul the bottom of the dash and other various bits
16-10-2012, 02:07 PM
You could probably only shim it another 3-5mm I reckon, otherwise you'll be running out of thread on the mounts...
16-10-2012, 02:09 PM
You might be stretching the loom abit thats going to the indicators, lights etc but if you only want 10mm it wont matter much..
17-10-2012, 10:24 AM
The loom for the indicators / ignition on my phase 3 had loads of slack on it!
I had trouble lining my rack back up after fitting the brake light switch, it's a b*stard of a job to get the front and rear support to line up all at once. Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
steering column volume control | Scouse282 | 5 | 4,769 |
09-11-2013, 09:48 AM Last Post: Scouse282 |
| Steering column bulkhead grommit.. | Tom | 14 | 8,890 |
27-12-2012, 11:33 PM Last Post: Piggy |
