Threads: 71
Car Model/Spec: 205 dt
My passenger door seal keeps filling up with water and then leaking inside but I've got no idea how its getting in, anyone had this before? Got any ideas how to stop it?
Threads: 171
46
there must be a hole somewhere, mine has one and its annoying, filling up my footwell :/
Threads: 100
Drill a hole on the outside for it to leak out.
There is no hole, it's just the volume of water over spilling over the seal into the car.
Threads: 71
I thought about that but wanted to find the root of the problem and fix that, is weird as I can't seem to see any wet parts round the top all appears to be in good condition no rips
Threads: 202
58
all of mine have done this in really heavy rain. if you have the option, park facing up hill, seems to be a good temporary fix
Threads: 100
Off to the job centre. HIDs look good.
Water gets in the seals at the top and then follows it to the bottom
Threads: 71
Hmm can't see anywhere guess will drill a small hole in the front and the back so it'll just drain through
Threads: 448
51
Just stick a Stanley blade along the bottom
Threads: 44
Car Model/Spec: 306 d turbo
i have exact same problem,i found if i park with the car slightley tilting to the passenger side i have no leaks but if the car is tilting to the drivers side it pours in and fills right up...fookin pain in the arse.
Threads: 100
The water runs down the middle of the seal the collects under the door and pools, it is spills over just below the speakers in the front doors. Just cut or drill a hole here to the outside and it will be fine
Threads: 71
Exactly what mine was doing so cut a small cross slit under each hole seems to be OK now
Threads: 82
27
Wish i'd read this thread before.. been doing it on the drivers side of my 6' and was a fair amount of water in there this morn lol
Threads: 71
I found a 3 inch puddle in my passenger side which gave me the incentive to do fix it! had to get a mop and bucket out!!
on the plus side it is nice and clean in there now
