Chopping gear stick
Chopping gear stick
Did this in my old 1.8 and it was much nicer. Cut about 2 inches off and it made the car much nicer to drive.
Now with the gti, can you cut them down? Its about 4 foot long! Only thing im thinking is how is the cable attached to the stick? is it just a clip i can slide down or do i need to do some serious pikey bodging with some liquid metal?
Some possible pikey bodging Wink
surely not worth messing about with the lift up reverse?
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
Cut and weld job would be best IMO, I made a cable pull thing to go on my cut down one that was hidden under the gator but it was a faf making it.
[Image: sig.jpg]
hmmm going to have to work some serious magic with the liquid metal then!
Cut it you wetty
306 HDI, soon to be XUD
Shut ya trap faggot. I like having reverse thanks!
Do what curt has done and cut that stick
Niall got a spare here that I can cut and weld if needs be.
[Image: sig.jpg]
no ones actually said, how is the cable attached/work?
[Image: signiture.jpg]
(28-09-2012, 12:11 PM)kernow_joe Wrote: no ones actually said, how is the cable attached/work?
This is what I'd like to know! Then I can work a solution.
Chris might take you up on that mate.
Theres a plastic sleeve bonded to the stick which the lift up collar sits on and holds the cable too.
Niall let me know and I'll get it sorted.
[Image: sig.jpg]
On the gear stick you have a plastic part glued to it. Quite solidly as I tried to remove it... This is what the plastic part of the cable clips in to. Then the lift reverse "collar" sits over this, which is where the end of the cable attaches to.
To do what you're wanting would take fair modification. I'd definitely recommend doing it to another one so you can just swap it, instead of mutilating your only one Wink
I think Chris is right, I think you'd have to cut a section out below the plastic part I mentioned, and weld it back together. Not worth the hassle IMO
I need to remove my gear knob/stick to fit quickshift, does it still just pull like other models but leave the reverse clips on the stick?
and will it be able to slide out the bottom still?
Just do a curt and do a bike lever conversion
(28-09-2012, 04:37 PM)puglove Wrote: Just do a curt and do a bike lever conversion
As much as i love that, i think id prefer just the standard setup tbh
Lol as cool as it is i wouldnt do it either ,
Just a thought, there are many cars/vans that use this system, run down the scrappy and if there is a version that is a bit more simple that you could use?
Brake lever conversion is epic winning though Tongue feels amazing when I put it on reverse, becauseRacecar
Do what Darrens done and use a solenoid? O:
Just been to look and the easiest way would be to chop and weld it.
[Image: CEE95CFC-3935-4A82-9674-11303237C984-521...D857E0.jpg]
That bit of plastic is bonded and can guarantee it isnt coming off in 1 piece. Peugeot dont sell it on its own Sad
What about my idea about using one off a different car/van, i know a peugeot expert uses this system with a real short gear box.
Forgot to say earlyer . When i go from DT to the 6 it feels massive gigity. To the point that its uncomfortable .
Tbh could pikey it right up, smash the bit of plastic off and cable tie the cable to the rod (would eventually slip up) or liquid metal it....because that shit fixes everything! Big Grin
do these work like vauxhalls? where you can still put it into any gear while the levers up?
yeah you can mate. dont see why youd want to though?
  Pressed plate stick lolsteve 13 7,193 09-06-2015, 10:56 PM
Last Post: Nathan1305
  Custom gear stick setup? DrewHughes 11 6,888 11-05-2014, 07:35 PM
Last Post: Piggy
  Gear stick sherman306 0 1,600 27-11-2013, 08:24 PM
Last Post: sherman306
