st st st stuttering
st st st stuttering
Was driving along the other day 1300 revs ish planted it and it stuttered asif it missed but it only does it at about that revs in any gear is that a flatspot in the map???
What engine is it?
(27-09-2012, 09:37 PM)Niall Wrote: What engine is it?
1.8 16v 1999
Thought so. Start with the basic. Check spark plugs. If not then new coil pack time. If that doesnt fix it, you probably need a new ecu.
The coil packs on the 1.8 break down and can short the ecu. Problem is the sagem ecu used on the 1.8 is so shockingly shit it either makes it do weird things or just stops it from working all together.
(27-09-2012, 09:46 PM)Niall Wrote: Thought so. Start with the basic. Check spark plugs. If not then new coil pack time. If that doesnt fix it, you probably need a new ecu.
Yh i got told the ecus are shite will go shopping then
Niall will make you one out of lego if you like? he has claimed in the past that he could make a better one out of lego so it will be better than the OE one, so its an upgrade rather than replacing it for an OE one.
But on a serious note i no nothing about the 1.8s so i will stop trolling and leave Big Grin
It would probably work better in all fairness!
Best work out a price and let him know then, TBH if its just lego i can image it will be pretty cheap lmao
I have a rather large quantity of Lego I can donate if needed?
could do but i cant guarantee it will make it into the form of a ECU. Maybe a boat or house or something.
God i miss playing with lego Sad
Build me 1
Case closed new plugs and wahoo i can overtake again
  S16 stuttering aggyj17 20 10,575 27-03-2013, 06:11 PM
Last Post: Jonny b
