Threads: 343
15
Well as above really, i started to fit an intercooler yesterday and the aircon rad fell to bits so i deiced im going to remove the aircon all together, so how do i remove the pump and what do i need to do?? what rote dose the new belt take? and what is the new belt?? (is it case of ask for one for my car but say it dosent have aircon?? ) Any help welcome as would like to remove it asap as it will make my root for the pipeing alot easyer
Threads: 343
15
yes i have hdi...... also posted in the hdi section lol
how dose the shorter belt fit?? what route dose it take?? and i dont need to swap anything else??
Threads: 79
17
You should be able to work out the belt routing, as far as i remember its not far off the original and its hard not to get it right, the pipes were a real pain to get out of mine from round the back. Just bend them till they snap and take them out bit by bit. The pump is just four bolts with a 16mm nut and bolt.
Threads: 343
15
soooooo theres 2 options then but looking at the second option the belt will need to be longer??
Threads: 189
10
Car Model/Spec: E39 ACS 535i
If you want to remove the pump there are 2 options.
1 use the shorter belt listed above with the original alternator and pas bracket.
2 use the full non air con bracket from a dw8 or dw10 and run the appropriate belt for that setup as cully has pictuered (which is what I've done on 2 (about to do the 3rd) of my cars and a mates)
Threads: 343
15
Think im gona go for the warlord option seems so much easyer
Just to confirm, 6pk1173 is a gates part number, otherwise pug parts guys should be able to find you a belt that's 6 notch and 1173mm long. Keep the bottom tensioner in place, it removes the long run from the bottom gives a little bit more wrap around the alternator pulley. I seem to remember that long run gave warlord problems with the belt slipping, hence why he ended copying the set-up i used (last pic).
Threads: 0
I ment on the net and i seen ur post just after and found it on ebay nice one mate thankyou
