Engine Remove Without Disturbing Aircon?
Hi
Is it possible to remove the engine without disturbing the Aircon by unbolting the compressor from the engine and tucking it out the way - i.e is there room if the engine will be coming out the top.
Thanks
Tom
the air con pump is fairly hefty... if you remove the aux belt and unbolted it etc i cant see why you couldnt get the engine out without disturbing it.
Yes it will come out the top so much easier just to disconnect it and get it re gassed
Team Doesn't own a 306
yes you can i sugest removing the rad so you can move the compressor onto the front crossmember as it is on flexy pipes
be carful though as the aircon rad will still be in place
Great - thanks guys. I was planning on removing the rad anyway
You can, makes life much easier
  Aircon LewisG 11 5,228 24-04-2014, 12:00 PM
Last Post: mcvite
  How do i Remove my aircon??? Chris_90 12 8,738 12-04-2013, 04:51 PM
Last Post: Majortom86
  aircon finchy 2 2,918 04-03-2013, 08:20 AM
Last Post: finchy
