Threads: 79
17
Got the air con out today and i have a vaccum hose thats been disconnected in the proccess. It runs from the top left of the engine bay and along the bulk head then goes down, where should it then connect to?!
Thanks for any help.
Ian
Threads: 22
6
Car Model/Spec: 306 HDi Stage 1
17-08-2012, 05:17 PM
(This post was last modified: 17-08-2012, 05:17 PM by gareth7.)
possibly the EGR valve by the sounds of it mate
Threads: 465
114
Car Model/Spec: Vauxhall
if its got blue tape marker on the end it part of the egr system, it goes to the air doser on the air inlet just before the manafold bend its a right bitch to get to
Threads: 79
17
No tape marker, its only got suction at low revs
Threads: 465
114
trace it back along the bulk head. does it go to a solinoid valve ?
or has it broken off from the vacuum pump conection block to the left of the battery against the bulkhead?
Threads: 79
17
Goes to a solinoid valve, theres two one above the other, its from the the 'out' of the top one
Threads: 465
114
yup as i said before then it goes to the air doser on the air inlet just before the manafold bend
