Help, disconnected vaccum pipe - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Help, disconnected vaccum pipe (/showthread.php?tid=5617) |
Help, disconnected vaccum pipe - Slam Wagon - 17-08-2012 Got the air con out today and i have a vaccum hose thats been disconnected in the proccess. It runs from the top left of the engine bay and along the bulk head then goes down, where should it then connect to?! Thanks for any help. Ian RE: Help, disconnected vaccum pipe - gareth7 - 17-08-2012 possibly the EGR valve by the sounds of it mate RE: Help, disconnected vaccum pipe - cully - 17-08-2012 if its got blue tape marker on the end it part of the egr system, it goes to the air doser on the air inlet just before the manafold bend its a right bitch to get to RE: Help, disconnected vaccum pipe - Slam Wagon - 17-08-2012 No tape marker, its only got suction at low revs RE: Help, disconnected vaccum pipe - cully - 17-08-2012 trace it back along the bulk head. does it go to a solinoid valve ? or has it broken off from the vacuum pump conection block to the left of the battery against the bulkhead? RE: Help, disconnected vaccum pipe - Slam Wagon - 17-08-2012 Goes to a solinoid valve, theres two one above the other, its from the the 'out' of the top one RE: Help, disconnected vaccum pipe - cully - 17-08-2012 yup as i said before then it goes to the air doser on the air inlet just before the manafold bend RE: Help, disconnected vaccum pipe - Slam Wagon - 17-08-2012 Awesome cheers. |
