Threads: 37
Taken my bonnet badge off, want to spray it all black and the lion green, can
I take the lion off so it's not messy? Tried lever it off with a knife but it just isn't happening.
Threads: 80
5
Car Model/Spec: 2006 Honda Civic 1.8 VTEC Ex
Given 5 thank(s) in 5 post(s)
Its bolted on. Theres just one nut to take off I think.
Open the bonnet and look underneath the badge.
Threads: 37
I've taken that off. Just want to take the silver bit off the actual badge to paint it
Threads: 71
4
Car Model/Spec: 205 dt
Is glued on I did the same as with head lights stick it in the oven, lightly prised it out with a Stanley blade
Threads: 448
51
I just pulled mine apart, it's glued and pinned.
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Yeah as matt :-) just pulled it off. Might break it though lol
Threads: 71
4
yeah thats why I heated mine up, not sure if it made a difference or not
Threads: 476
81
Car Model/Spec: 306 Rallye
i heated mine and drilled out the sprews and still broke it. Id suggest just masking it off. I did that on mine and its a really impressive job seeing as it took 15 minutes!
Threads: 22
6
Car Model/Spec: 306 HDi Stage 1
Use a drill......very carefully.......10 second job
Threads: 71
4
don't be a heavy handed twat and heat it and gently lever under each point that its held, easy to see from the back where the fixing points are, then you can do a proper job of it, same goes for the surround
Threads: 37
Just sprayed it all black was too much of a ball ache hahaha
