Grinding at 3000rpm
Grinding at 3000rpm
Possible gearbox mount so I've been told, anyone had this problem?
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Sounds more likely to be a driveshaft or CV joint, although 'griding' is hard to pin point without hearing it in person.
(15-08-2012, 05:35 PM)Dan! Wrote: Sounds more likely to be a driveshaft or CV joint, although 'griding' is hard to pin point without hearing it in person.
You can feel it under peddles and just noticed the engine sorta moves more than normal when down changing
Does it grind in every gear?
Have you sorted this problem, dont know if this could be but i have a bad vibration on the peddles and a bit of a grinding noise turned out the pump bracket was cracked causing vibrations
[Image: J5hxCcC.jpg]
  Knocking / grinding when driving help. Danny2009 8 4,125 22-08-2012, 11:34 AM
Last Post: Danny2009
  grinding noise studturbo 4 3,154 12-01-2012, 01:48 PM
Last Post: studturbo
