ph3 glove box
ph3 glove box
seams to be alot of talk of glove boxes so here goes. my lock for my glove box is fuucked and is held in by a screw to stop it from opening. how hard is it to change.
New glove box in there maybe easier?
There isn't a real difference in the glove boxes through the phases, its the A/c or non-A/C models that differ greatly in depth
Lock is easy to change Smile
(09-07-2012, 07:57 PM)4WayDiablo Wrote: There isn't a real difference in the glove boxes through the phases, its the A/c or non-A/C models that differ greatly in depth
I guess its not a straight swap putting a non ac into an ac one?
I guess you would have to remove your aircon from behind your dash or at least re locate it
literally pop the locks out from the inside bud, get a new lock from the scrappy and fit it where the old one was and snap the little plastic lock bit off inside and it will stay shut and also opens, you just cant lock it
306 HDI, soon to be XUD
i could never work out how to remove the glove box from my 1.4 Sad
With a bit of heat and careful separation you should be able to prise the 2 halves of the glovebox apart - I did on my ph1 swapped the locks over and bonded it back together with 2 people using 2 hot melt glue guns as you need to be quick or the hot melt goes cold quickly. I could of used tiger seal but never thought about it at the time.
(09-07-2012, 09:48 PM)declantg Wrote: literally pop the locks out from the inside bud, get a new lock from the scrappy and fit it where the old one was and snap the little plastic lock bit off inside and it will stay shut and also opens, you just cant lock it
thats the kind of answer i was looking for. cheers matey..... reppedItwasntme
  Locking glove box Mighty306 4 2,616 12-02-2018, 03:57 PM
Last Post: gti6man
  glove box kiffer850 4 2,846 17-04-2013, 11:18 AM
Last Post: kiffer850
