glove box
Hi there
Does anybody know how to remove the lower glove box on a phase 2? THe lock on mine has jammed and now its permanently left open after using a bit of force to get in. I need to either change the lock or the whole box, whatevers easier. I've seen some 306's with the handle over towards the centre console but mine is in the middle. Any ideas? Thanks
The lock you can push through from the inside, made easier if you have not airbag in the bash as you can take the top box out.
If you want to remove the glove box, then lie head first in the footwell remove the lining and you should be able to see the two hinges. Each hinge has a plastic peg through it. Grip the end and then hit it with a hammer to push the peg back through the hinge then it will come out.
cool, thanks, i'll give it a go, unfortunately i have a top air bag
hope helping a scummer wasn't too painful for you ;-)
I am not from around here so it's not grown into me from a young age to hate our local scum neighbours.
good man, it isn't healthy!
  Locking glove box Mighty306 4 3,576 12-02-2018, 03:57 PM
Last Post: gti6man
  ph3 glove box kingy 9 8,516 10-07-2012, 07:45 PM
Last Post: kingy
