Turbo Boost and model
Question
Only getting max boost around 16/17 psi with the wastegate arm on last 2 turns and running max fuel! Also any ideas on which turbo I have??
306 dturbo s xud 1998 S-reg
Scott
Could be a worn wastegate being pushed open or a boost leak
Don't know what turbo it is though. Being a later model I'd think ko3 or similar
turbo seems rather leaky
www.prestige-auto-care.co.uk
Ive noticed in first or second before the the boost has just dumped at around like 3500 4000 revs causing the car to slow down massively like I put the brakes on!
going down motorway and stuff it will stay at a constant boost no problem
Btw when I mean max fuel i mean 45degree's or slightly more on lucas pump!
The manifold looks different to my old T2 and k14 so i'm guessing it's a GT15
Stage 2 XUD Sedan
That's a k03 should got more out of it than that mines boosting 1.4bar .
What you mean before "the boost has just dumped"
(09-07-2012, 09:10 PM)4WayDiablo Wrote: What you mean before "the boost has just dumped"
sometimes the boost just dumps around those revs in first and maybe second! I just loose all pressure and it slows the car down massively like I have put on the brakes.
(09-07-2012, 09:10 PM)ash23 Wrote: That's a k03 should got more out of it than that mines boosting 1.4bar .
how much did you tune your lucas to get that 1.4 bar?? and is your waste-gate arm really short like mine? like on the last few threads
have you checked all your piping?
(11-07-2012, 03:08 PM)Mowle5677 Wrote: have you checked all your piping?
seems fine to me but im not great with cars lol
this is a video of it running a few months back at stock - http://www.youtube.com/watch?v=vDkf-WcYe...ature=plcp
Make sure there are no leaks. And fit a MBC to adjust boost easier
28psi here (1.9 bar) on a K03 here!
But sounds like a busted turbo; I shouldn't cut off, at higher rpm, the turbo will start to loose boost..
if it is a busted turbo then drive it normally but i say its bigger turbo time Wink
Was going to upgrade to a T2 what do you think??
go big, or go home. td04 or the like Big Grin
not that i know anything about dervs, but from what i know, the t2 is the 'best' standard turbo they put on. might as well get a big un on it for more gains and whatnot
Pretty much what amass says.:-)
  Maximum safe boost on 2.1 TD on std. turbo? B1ack_Mi16 18 12,661 19-12-2013, 01:15 PM
Last Post: Dum-Dum
  aux belt tensioner a/c model removal? help CJ_Derv 2 2,954 09-06-2013, 11:03 AM
Last Post: CJ_Derv
  TD04 Model Codes bigcheez2k3 2 3,208 09-02-2013, 10:49 AM
Last Post: Ruan
