23-11-2012, 01:50 PM
Hi guys,
Bit of an odd one, my HDi whistles similar to a kettle when I put it to ignition on before starting.....its not the fuel pump as the noise is somewhere in the bay. Doesn't do it every time, but does do it every time after its been left for a while (an hour or so). Lasts for about 5 seconds, and carries on making the noise if I start the engine before that 5 seconds is up.
Any idea what it is? As I didn't think there should be anything 'moving' before starting the engine, so no idea what the noise is.
Also, seperate issue, theres a 'ringing' noise when I clutch in - is that the thrust bearing wearing out and making that noise as it spins down on the input shaft?
Cheers
Tom
Cheers
Tom
