HDi Whistling......BEFORE Starting! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: HDi Whistling......BEFORE Starting! (/showthread.php?tid=8260) |
HDi Whistling......BEFORE Starting! - Toms306 - 23-11-2012 Hi guys, Bit of an odd one, my HDi whistles similar to a kettle when I put it to ignition on before starting.....its not the fuel pump as the noise is somewhere in the bay. Doesn't do it every time, but does do it every time after its been left for a while (an hour or so). Lasts for about 5 seconds, and carries on making the noise if I start the engine before that 5 seconds is up. Any idea what it is? As I didn't think there should be anything 'moving' before starting the engine, so no idea what the noise is. Also, seperate issue, theres a 'ringing' noise when I clutch in - is that the thrust bearing wearing out and making that noise as it spins down on the input shaft? Cheers Tom RE: HDi Whistling......BEFORE Starting! - Just Sean - 23-11-2012 ahhh... im glad your back! RE: HDi Whistling......BEFORE Starting! - Toms306 - 23-11-2012 Helpful as ever Sean....
RE: HDi Whistling......BEFORE Starting! - Just Sean - 23-11-2012 has your 306 eaten a bird? With a waitor? RE: HDi Whistling......BEFORE Starting! - samass - 23-11-2012 Flux capacitor coming up to charge. Nothing to worry about. RE: HDi Whistling......BEFORE Starting! - CJ_Derv - 23-11-2012 Ive had a chirping when my bumper ate a bird, was inches away from air flow pipe could have been nasty RE: HDi Whistling......BEFORE Starting! - cully - 23-11-2012 drivers inerwing plastic fuel pipes whistle or hum on the earlyer HDI cars i think pug fitted a mod to the lines on some its caused buy the lowpressure fuel pump priming the system
RE: HDi Whistling......BEFORE Starting! - Toms306 - 23-11-2012 Never heard of that before lol, but yeah it is an earlyish one (W reg) so I'll take your word for that being the issue then. RE: HDi Whistling......BEFORE Starting! - Jonny81191 - 23-11-2012 It's your giraffe filtration system mate. It's really expensive too. Sucks. And the release bearing would make that noise.. Just leave it be until it packs up. RE: HDi Whistling......BEFORE Starting! - Toms306 - 23-11-2012 (23-11-2012, 07:33 PM)Jonny81191 Wrote: It's your giraffe filtration system mate. It's really expensive too. Sucks. Ah f*ck, better get down to Peugeot in the morning and order one then.....anyone got the part number? ![]() And oh dear, thought it would be that bearing, just hope it and the clutch last until I sell the car then! |
