26-09-2012, 07:54 PM
Hi guys I was thinking about cambering my wheels is there a bolt or set anyone knows about that will fit 306s any help appreciated.
Camber adjusting bolts for 306?
26-09-2012, 08:01 PM
you cant camber the rear and adjustable top mounts for the front
26-09-2012, 08:03 PM
actually you can camber the rear, but it involves having the trailing arms machined.
26-09-2012, 08:05 PM
^^^ What Jonny 81191118299192837472921119222911 said.
A company called BakerBM machine the trailing arms to camber the rear. IIRC it is circa £200 for this to be done. Eccentric top mounts, or fully adjustable topmounts for the fronts. Best thing you will ever do to your 306
26-09-2012, 08:06 PM
or just buy a fecked beam?
26-09-2012, 08:08 PM
Which has so much play in it, it handles like the pedophiles disabled dog in family guy.
Not fun, Ive been there lol. Solid rear mounts for the win too! Anyhow Topmounts ![]() Maximuim camber you can run without chopping turrets around:
26-09-2012, 08:37 PM
and the sarcasm was lost over the internet.. again.
26-09-2012, 11:52 PM
best bit is, those top mounts grant have are only £135 brand new from spoox.
and jonny, on the internet, you always lose. and you're short. and northern. just sayin... Member of the 99% warning or you're nothing club
27-09-2012, 12:18 AM
and you drive a supertanker.
27-09-2012, 12:20 AM
and that, is winning.
i can be seen from space, deffo winning! Member of the 99% warning or you're nothing club
27-09-2012, 12:22 AM
but you also need an aicraft control tower to park it, and it has the handling of a bendy bus. And that, is failing.
27-09-2012, 12:24 AM
actually, it doesnt handle too badly. tap the brakes before you turn in, helps the front bite and the back slip a lil
![]() but either way, hooning a volvo estate, is winning Member of the 99% warning or you're nothing club |
| Camber/axle swap | panzer | 2 | 2,264 |
17-07-2015, 11:01 PM Last Post: Stef205 |
| Negative Camber | Snell | 16 | 8,208 |
18-01-2015, 05:35 PM Last Post: Snell |
| adjusting rear drums | philpemberton94 | 12 | 6,042 |
19-09-2014, 01:42 PM Last Post: philpemberton94 |
