will these fail an MOT..
So got my mot this weekend just wanna be ready if it fails so here are bits I'm worried about.
Running defilter
t piece in brake vacuum for when I tried a DV
low discs and pads (upgrading soon so no point replacing)
lower engine mount knocking pretty badly
decat
306 HDI, soon to be XUD
From what i can tell none of that should cause it to fail, if they fail it for a decat then you should probably go to another garage...
That's okay then, just hoping I don't suffer the 5dr rusty arches Sad
Rusty arch wouldn't fail anyway, only if it's structural and within 30cm diameter of a wheel IIRC
Declan its not just 5 doors I don't think. Think it's mainly ph1s and 2s
This is starting to make me worry less about it! Every day my dad tells me it will fail...
End of the day mate, worst case it fails, best case it passes, just chill bro Smile
Was hoping to pick up some seats this weekend though! Annoying as I have work 2-10 everyday now. So can't just sort bits out!
Depends how low the pads are and what state the discs are in, could fail it on those
Ahh must've somehow missed that.. my rear pads were fairly low... only got an advisory for them though
Like i said, depends how low, under 1.5mm is a fail
wont fail on engine mounts or defilter as mine passed with both those =L
On the 306 waiting list.
There is a limit on brake pad depth although they're not allowed to take the wheel off to check :-) must be visual
rusty wheel arches do fail mot, as jagged edges are a risk to pedestrians
if you can see through the whel trim/alloy wheel ,then if pads look to be below 1.5 mm they fail.
should all be good if the pads are not too low and the discs are in a ok condition, think im right in saying engine mounts are not looked at in the test? and they cant fail the de filter or the de cat! Smile
Blaze '6 and Blaze D-turbo!
Brakes will more than likely be an advisory unless they're that bad lol, also Id expect 'oil leak' which I had advised on most of my pugs lol. And headlight aim will probably be out (which is a fail if bad enough) but they should just adjust this for you anyway.
