Tdo4 boost problem
Trying to solve a problem on tdo4l powered xud. It's running a 11mm pump, lda pin grind, dewast gated and solid gov shim.But it won't boost past 22psi at all tried all sorts to get it too boost past but just won't go past 22 any ideas?
Cheers
www.prestige-auto-care.co.uk
I've not played around too much with the TD04's myself, but it could be the wastegate spring is being forced open by the exhaust gasses?
You mention that it is de-wastegated, has the hotside actually had some welding done to it?
Captain Standard
Pressurise your intake system, show boost leaks, especially around your inlet gasket
Could be the wastegate still trying to open by the exhaust gases you should weld the gate shut
Bye Bye D-Turbo
+1 on the wastegate opening. My T2 does this, it's on the standard setting but the actuator feeds been block now. Hit's a wall at 27psi due to the gate opening itself.
Stage 2 XUD Sedan
Well inlet has threaded a bolts so that appears to be the problem! Couldn't pressure the system enough so sprayed wd round inlet and engine revd it self
The threads for inlet/ exhaust manifolds don't last long after several turbo changes.
Bye Bye D-Turbo
Boost leak and I bet you the gate is still blowing open.
i reckon its the semi ecu controlled pump thats on it lol.
Wastegate isnt any good to them.
I swapped mine to one from a 325tds td04. Problem solved and it seems to have reduced the lag in the boost building.
Tongue tdo4 on xud mrmoates 2 3,453 18-09-2017, 11:25 PM
Last Post: Dave
  Ko3 upgrade. t2/tdo4 daveylennon93 6 3,890 10-07-2014, 08:22 PM
Last Post: daveylennon93
  Tdo4 airfilter Daniel306 5 3,618 01-02-2014, 09:08 PM
Last Post: clarkey2010
