Tdo4 airfilter
Tdo4 airfilter, how have you done yours?
I ran de filtered Big Grin naughty but sounded EPIC!!!!
Iv got 2.25 aluminium pipe from the turbo to the master cylinder then a silocone 90 forwards to a 90 down behind the headlight, problem is that is sucks the 90's closed and i cant fit a bigger filter. think i may need to relocate the washer bottle, cut the filler hole bigger and make a airbox for it
If i remove the filter it runs much better(makes a 500mile clutch slip) but its just sounds like a boost leak
guessing you cant route it like the standard turbo? OEM style!
Need an expanding 90 and bigger pipework...
any project thread worth looking at for routing and filter for the TD04 etc being sniffing through but cant find much (sorry for the hijack)
Tongue tdo4 on xud mrmoates 2 3,452 18-09-2017, 11:25 PM
Last Post: Dave
  Ko3 upgrade. t2/tdo4 daveylennon93 6 3,876 10-07-2014, 08:22 PM
Last Post: daveylennon93
  anyone used or using this type of TDO4 karl1989 19 12,838 05-12-2012, 06:52 PM
Last Post: Tom
