drive shats from a 1.9 td fit the 1.8?
hi guys
i'm doing a friends 1.8 306 needs a drivers side drive shaft i have a few good 1.9td xud shafts about will they fit the 1.8?
looking up on ebay they list them as fitting the 1.9td and the 1.8
1.8 and up all use the same size shafts afaik. Only difference is if you need ABS ring or not.
