drive shats from a 1.9 td fit the 1.8? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: drive shats from a 1.9 td fit the 1.8? (/showthread.php?tid=35044) |
drive shats from a 1.9 td fit the 1.8? - maxlee - 22-10-2016 hi guys i'm doing a friends 1.8 306 needs a drivers side drive shaft i have a few good 1.9td xud shafts about will they fit the 1.8? looking up on ebay they list them as fitting the 1.9td and the 1.8 RE: drive shats from a 1.9 td fit the 1.8? - Toms306 - 22-10-2016 1.8 and up all use the same size shafts afaik. Only difference is if you need ABS ring or not. |
