Threads: 129
11
I've found a L200 turbo for sale locally to me and after a quick search it appears they are a TD04. The add info's vague and doesn't say the year.
Does anyone know the numbers I should look out for if I go have a look?
Stage 2 XUD Sedan
Threads: 9
19
Given 3 thank(s) in 1 post(s)
*shakes head* it will be a "H" or "HL" one on the L200, you want a "TD04L 13T" off an Impreza  I haven't forgotten about PMing you either, just not had chance yet
Just send me a PM with what you know already and what you want to know, save me teaching you how to suck eggs
Threads: 129
11
Ok cheers for that, i'll give it a miss.
Stage 2 XUD Sedan
Threads: 20
Car Model/Spec: Durbo
Someone needs to do a 16t td04 ;D
Threads: 9
19
Matty Wrote:Someone needs to do a 16t td04 ;D
I have been looking at the bigger compressor wheels and my last convo with Ruan has given me bad ideas!
Threads: 20
ROFL..pahahahahahahaa. No, there not bad ideas. There good ideas. Do it. :evil:
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Both l200s my dads had have had vnt looking turbos with twin actuator arms.
And tbh there not that big either.
Threads: 9
19
Chris Wrote:Both l200s my dads had have had vnt looking turbos with twin actuator arms.
Depends on the age of them really though doesn't it, the older ones (more likely to be in a scrap yard than a new one I would think) have TD04 variant turbo's on but yes they are fairly tiny TBH
Threads: 20
All our usual suspect turbo's are small aren't they really. Just relatively big for our engines etc.
Threads: 9
19
Matty Wrote:All our usual suspect turbo's are small aren't they really. Just relatively big for our engines etc.
True but the L200 ones particularly so as they are designed to boost up quick....
need one of these
http://www.ebay.co.uk/itm/Turbocharger- ... 2525wt_952
Threads: 20
my o my. Do it Mark, do it!!!! ;DDDD Would be very sexual. #giggity
Threads: 9
19
Matty Wrote:my o my. Do it Mark, do it!!!! ;DDDD Would be very sexual. #giggity
No, I want my engine internals to remain internal and not all over the road via a huge hole in the case
this is cheap BTW is someone is quick
http://www.ebay.co.uk/itm/TD04-Turbo-fo ... _500wt_949
Threads: 20
Bah. Engine internals to remain internal? What a conformist. teehee.
Threads: 9
19
Matty Wrote:Bah. Engine internals to remain internal? What a conformist. teehee.
I know right, cyclones and 40mm drop to come soon
Threads: 20
ROFL. What a boss. Be careful you don't set any trends Mark.
Threads: 96
7
Car Model/Spec: 306 tractor
mark_airey Wrote:I know right, cyclones and 40mm drop to come soon
That's my next step....don't copy me
Threads: 129
11
Dam I was to busy polishing and waxing my car and just missed the TD04
Stage 2 XUD Sedan
Threads: 9
19
strictly_derv Wrote:Dam I was to busy polishing and waxing my car and just missed the TD04
There are a few for reasonable money on ebay atm, I will stick some links in my PM later
Sorry for spamming the crap out of your thread again! I blame Matty
Threads: 129
11
Threads: 20
teehee. My fault as per.
Threads: 129
11
A mate's having his TT 225 engine rebuilt and is having the turbo replaced while it's apart. It's running a k04, would this be any good? The engine has 225 bhp as standard so it must be fairly good for what i'm after.
Does anyone know much about these?
Stage 2 XUD Sedan
