aright guys ive been offerd some brembo brake callipers and disks from a series 2 rs turbine.. apparently they are quite big and only fit under 17,s .. my question is are they largely interchangeable .. as in with a bit of tinkering will i get them to fit on my 6?.. the bolt pattern is the same would i have to make up or source a carrier ?.. any advice would be ideal... cheers
rs turbo brembo's?
radial mount them probably have to use rotots and custom bells to make them fit.
Would definitely have to make mounts up for them and lines .I d personally steer well clear and get either 406 brembos,hi spec or willwods Astor 6 Fast road/track project
27-03-2014, 06:56 PM
ok thanks .. ile leave them then .. cheers for saving me a "hell" mission .. ;-)
27-03-2014, 06:59 PM
Aftermarket kits can be picked up cheap if you keep an eye out. I picked up my Hispec kit for 280 but they were for a 106 originally so i had to spend 40 on new lines.
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft |
| Brembo Rebuild | CJ_Derv | 14 | 8,828 |
06-01-2013, 10:50 AM Last Post: CJ_Derv |
| V6 Brembo | gurj306 | 9 | 6,889 |
14-07-2012, 11:09 PM Last Post: gurj306 |
| 3.0 V6 Brembo's | 4WayDiablo | 35 | 18,814 |
13-02-2012, 07:12 PM Last Post: Jonny b |
