Little fix for those stupid rubbish HDi engine cover mounts which are...well rubbish and break a lot:
Guide: HDi cover mounts...fix :)
09-12-2014, 01:30 PM
Ive done this before. Works fine but you need to have the right height of bobbin! What ar eyours? 20mm of rubber?
09-12-2014, 01:31 PM
Yeah about that. Must add that to the description.
Ive got some better tops on order so will update when they arrive. Wishes for more power...
09-12-2014, 03:15 PM
Something quick release would be so much better
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
09-12-2014, 03:22 PM
(09-12-2014, 03:15 PM)Connor Wrote: Something quick release would be so much better Even wing nuts would be better than just m6 nuts James? http://www.screwfix.com/p/wing-nuts-bzp-...f-10/17304
09-12-2014, 03:28 PM
So you either can get nut covers...
http://www.ebay.co.uk/itm/PROTECTIVE-COV...258cce4a9f What i think I might do is get some M6 bolts and make something up that looks a bit funky... Spacers to raise the cover up http://www.ebay.co.uk/itm/Black-Nylon-Pl...462cdb7747 some funky decorative countersunk washers preferably without jap stuff all over them. http://www.ebay.co.uk/itm/10-PIECES-M6-x...5d52bd5739 and whatever length of M6 bolt is needed to go through it all. Probably in black. http://www.ebay.co.uk/itm/M6-6mm-BLACK-A...338e0ed603
09-12-2014, 03:30 PM
What is the length of the bobbin piggy? Need to work out how long the bolts need to be.
Is there anything which has a female thread and a male thread? So like the bobbin but allows a bolt to be screwed into the top of bobbin some kind of bolt extender? like this... ![]()
09-12-2014, 05:13 PM
Yeah but wingnuts come loose.
As Sam is looking at those would be better. Covers or something similar. Wishes for more power...
09-12-2014, 07:32 PM
I still don't know what the bits in that picture are called. Volt extenders is all I've come up with...
09-12-2014, 07:48 PM
(This post was last modified: 09-12-2014, 07:49 PM by tigerstyle.)
10-12-2014, 05:13 PM
10-12-2014, 05:19 PM
I'm sure if I had any to begin with, id still have them
![]() 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
11-12-2014, 10:40 AM
I lost all of mine.
These could be useful for someone to keep it looking oem http://www.ebay.co.uk/itm/10-BLACK-Plast...4614272f9d
11-12-2014, 11:27 AM
Right. Still looking at a way of making it look tidy so i can use my bolts and finishing washers...
What we/I really want is a 20mm M/F M6 standoff like style 2 below. ![]() http://uk.farnell.com/richco/htsa-m6-20-...dp/1898540 |
