Guide: HDi cover mounts...fix :) - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Guides (https://www.306oc.co.uk/forum/forumdisplay.php?fid=9) +--- Thread: Guide: HDi cover mounts...fix :) (/showthread.php?tid=28151) |
HDi cover mounts...fix :) - Piggy - 05-12-2014 Little fix for those stupid rubbish HDi engine cover mounts which are...well rubbish and break a lot: RE: HDi cover mounts...fix :) - Eeyore - 09-12-2014 Ive done this before. Works fine but you need to have the right height of bobbin! What ar eyours? 20mm of rubber? RE: HDi cover mounts...fix :) - Piggy - 09-12-2014 Yeah about that. Must add that to the description. Ive got some better tops on order so will update when they arrive. RE: HDi cover mounts...fix :) - Connor - 09-12-2014 Something quick release would be so much better RE: HDi cover mounts...fix :) - 1616six - 09-12-2014 (09-12-2014, 03:15 PM)Connor Wrote: Something quick release would be so much better Even wing nuts would be better than just m6 nuts James? http://www.screwfix.com/p/wing-nuts-bzp-steel-m6-pack-of-10/17304 RE: HDi cover mounts...fix :) - Eeyore - 09-12-2014 So you either can get nut covers... http://www.ebay.co.uk/itm/PROTECTIVE-COVER-CAPS-FOR-HEXAGON-NUTS-BOLTS-SCREWS-BLACK-PLASTIC-FREE-P-P-/161276119711?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item258cce4a9f What i think I might do is get some M6 bolts and make something up that looks a bit funky... Spacers to raise the cover up http://www.ebay.co.uk/itm/Black-Nylon-Plastic-SPACERS-Standoff-Washer-M3-M4-M5-M6-M8-or-M10-Pack-of-12-/301400291143?pt=UK_DIY_Material_Nails_Fixing_MJ&var=600371081163&hash=item462cdb7747 some funky decorative countersunk washers preferably without jap stuff all over them. http://www.ebay.co.uk/itm/10-PIECES-M6-x-20mm-RED-Billet-ALUMINUM-Fender-Bolt-Screw-Decorative-WASHERS-/400820098873?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d52bd5739 and whatever length of M6 bolt is needed to go through it all. Probably in black. http://www.ebay.co.uk/itm/M6-6mm-BLACK-A2-STAINLESS-STEEL-SOCKET-COUNTER-SUNK-SCREWS-ALLEN-KEY-BOLTS-/221426669059?pt=UK_DIY_Material_Nails_Fixing_MJ&var=520409216011&hash=item338e0ed603 RE: HDi cover mounts...fix :) - Eeyore - 09-12-2014 What is the length of the bobbin piggy? Need to work out how long the bolts need to be. Is there anything which has a female thread and a male thread? So like the bobbin but allows a bolt to be screwed into the top of bobbin some kind of bolt extender? like this... ![]() RE: HDi cover mounts...fix :) - Piggy - 09-12-2014 Yeah but wingnuts come loose. As Sam is looking at those would be better. Covers or something similar. RE: HDi cover mounts...fix :) - Eeyore - 09-12-2014 I still don't know what the bits in that picture are called. Volt extenders is all I've come up with... RE: HDi cover mounts...fix :) - tigerstyle - 09-12-2014 (09-12-2014, 07:32 PM)SRowell Wrote: I still don't know what the bits in that picture are called. Volt extenders is all I've come up with... 1/4" hex standoffs 6mm hex standoffs RE: HDi cover mounts...fix :) - Piggy - 10-12-2014 For some help: [attachment=20580] ![]() RE: HDi cover mounts...fix :) - Toms306 - 10-12-2014 (09-12-2014, 03:15 PM)Connor Wrote: Something quick release would be so much better If only Peugeot had thought of this and made some quick push-fit, twist-release clips...oh wait.... ![]() I don't know how people so many issues with the genuine ones tbh, I haven't lost any for ages! RE: HDi cover mounts...fix :) - Connor - 10-12-2014 I'm sure if I had any to begin with, id still have them ![]() RE: HDi cover mounts...fix :) - Eeyore - 11-12-2014 I lost all of mine. These could be useful for someone to keep it looking oem http://www.ebay.co.uk/itm/10-BLACK-Plastic-Nylon-M6-Thumb-Nuts-Without-Collar-20mm-OD-Knurled-/300985823133?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item4614272f9d RE: HDi cover mounts...fix :) - Eeyore - 11-12-2014 Right. Still looking at a way of making it look tidy so i can use my bolts and finishing washers... What we/I really want is a 20mm M/F M6 standoff like style 2 below. ![]() http://uk.farnell.com/richco/htsa-m6-20-2/aluminium-spacer-m-f-m6-20mm-high/dp/1898540 |
