21
looking for part numbers for a 1.6 petrol ph3 100bhp xreg 2000
panel filter???
oil filter???
petrol filter???
and anything else i need for a full service.
21
need the parts numbers cully.
Threads: 465
114
Car Model/Spec: Vauxhall
different factors will use different numbers
i guess you want pug numbers?
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Unipart usually provide a decent service and product...
Oh, and unipart although when boxed it says their sparks are home branded - they're actually NGK
read the small print!
Phaes 1 GTI 6 - Onyx Black
21
just want to give my motor a major service but when i looked on ebay it all seams a bit confusing. like i have a panel filter but alot of them are round filters for the 1.6?
just need to know what i need thats all mate.
Threads: 376
38
kingy Wrote:just want to give my motor a major service but when i looked on ebay it all seams a bit confusing. like i have a panel filter but alot of them are round filters for the 1.6?
yep, give you reg to unipart and they'll sort you out - wouldn't worry about part numbers unless you're going to go pug direct.. which you won't because thats a waste of money.
21
ok will do matey peeps. just thought i would try ebay but unipart it is. do gsf do the same?
Threads: 465
114
a quick look at service box for TU5 Jp 90hp brought up these (maynot be right for your aged car)
AIR FILTER 00001444ST (round) or AIR FILTER 00001444VY (panel)
SPARK-PLUG 00005960F0
OIL FILTER E149102 or canaster type E149104 OIL FILTER
SUMP PLUG SEAL 0000016488
FUEL FILTER E145004
Threads: 465
114
i recon your car is the
TU5JP INJECTION 100 HP AND L4 VEHICLE TECHNICAL DEPOLLUTION
model
21
cheers for that cully. will have a look at them.
edit.. it is the 100bhp model.
think its easier to go to unipart and let them sort it lol
Threads: 465
114
in that case
OIL FILTER 149104 canaster type not metal screwon
FUEL FILTER E145004
Pug really aren't bad for service parts tbh, my local one isn't anyway.
