part numbers. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: part numbers. (/showthread.php?tid=2041) |
part numbers. - kingy - 06-03-2012 looking for part numbers for a 1.6 petrol ph3 100bhp xreg 2000 panel filter??? oil filter??? petrol filter??? and anything else i need for a full service. Re: part numbers. - cully - 06-03-2012 spark plugs ! Re: part numbers. - kingy - 06-03-2012 need the parts numbers cully. Re: part numbers. - cully - 06-03-2012 different factors will use different numbers i guess you want pug numbers? Re: part numbers. - ginge191 - 06-03-2012 Unipart usually provide a decent service and product... Oh, and unipart although when boxed it says their sparks are home branded - they're actually NGK read the small print!
Re: part numbers. - kingy - 06-03-2012 just want to give my motor a major service but when i looked on ebay it all seams a bit confusing. like i have a panel filter but alot of them are round filters for the 1.6? just need to know what i need thats all mate. Re: part numbers. - ginge191 - 06-03-2012 kingy Wrote:just want to give my motor a major service but when i looked on ebay it all seams a bit confusing. like i have a panel filter but alot of them are round filters for the 1.6? yep, give you reg to unipart and they'll sort you out - wouldn't worry about part numbers unless you're going to go pug direct.. which you won't because thats a waste of money. Re: part numbers. - kingy - 06-03-2012 ok will do matey peeps. just thought i would try ebay but unipart it is. do gsf do the same? Re: part numbers. - cully - 06-03-2012 a quick look at service box for TU5 Jp 90hp brought up these (maynot be right for your aged car) AIR FILTER 00001444ST (round) or AIR FILTER 00001444VY (panel) SPARK-PLUG 00005960F0 OIL FILTER E149102 or canaster type E149104 OIL FILTER SUMP PLUG SEAL 0000016488 FUEL FILTER E145004 Re: part numbers. - cully - 06-03-2012 i recon your car is the TU5JP INJECTION 100 HP AND L4 VEHICLE TECHNICAL DEPOLLUTION model Re: part numbers. - kingy - 06-03-2012 cheers for that cully. will have a look at them. edit.. it is the 100bhp model. think its easier to go to unipart and let them sort it lol Re: part numbers. - cully - 06-03-2012 in that case AIR FILTER 00001444VY (panel) SPARK-PLUG 00005960F0 OIL FILTER 149104 canaster type not metal screwon SUMP PLUG SEAL 0000016488 FUEL FILTER E145004 Re: part numbers. - kingy - 06-03-2012 top man cully. Re: part numbers. - Poodle - 07-03-2012 Pug really aren't bad for service parts tbh, my local one isn't anyway. |
