GT2056s oil feed question
Hoping this is a simple question since these have been fitted a few times. Can anyone confirm if the oil feed on one of these is M10x1 and if it needs to be restricted to 1.5mm please?
The turbo is from an Iveco and has a 4 bolt flange. It's all mounted ok and clocked to suit the oil drain from the standard turbo. (engine is an XUD9) Just need to work out how to get the oil into the top of it.
No need for a restrictor on these.
That's great, thanks a lot.
  Problem turbo pressure gt2056s niciou 6 6,565 30-03-2017, 06:41 PM
Last Post: niciou
  lb/ft max gt2056s niciou 0 2,189 13-03-2017, 10:31 AM
Last Post: niciou
  spool turbo gt2056s niciou 11 7,321 05-07-2016, 08:12 PM
Last Post: Piggy
