Peugeot 206 fan & A/C dead...
Interior fan and A/C not working...
Happened like a fuse blown...fan not work on 1-4, A/C button clicks but no light/compressor not engage.
Yet no fuses blown...
Any thoughts...chucked it down before could get multimeter out
Sounds like the fan unit its self.
(26-06-2016, 09:00 AM)bashbarnard Wrote: Sounds like the fan unit its self.
Would that cause the A/C button to not work?!
So...
With the fan unplugged I get 3.57volts across the two supply pins on settings 1-4.
With the A/C button pressed I get 0.57volts on settings 1-4
With the fan plugged in I get 0 volts on all settings.
All fuses tested out fine.
Supply to the small section of fuses on the fuseboard that AC and fan are on isnt supply 12v and the 3.57/.57 is a feedback.
(206 fuseboard is split)
Ignition barrel getting full 12v supply on both lines...
But ignition barrel not givint out the 12v needed...
So guess this barrel is dead for sure
