Peugeot 206 fan & A/C dead... - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: Peugeot 206 fan & A/C dead... (/showthread.php?tid=34419) |
Peugeot 206 fan & A/C dead... - Piggy - 25-06-2016 Interior fan and A/C not working... Happened like a fuse blown...fan not work on 1-4, A/C button clicks but no light/compressor not engage. Yet no fuses blown... Any thoughts...chucked it down before could get multimeter out Peugeot 206 fan & A/C dead... - bashbarnard - 26-06-2016 Sounds like the fan unit its self. RE: Peugeot 206 fan & A/C dead... - Piggy - 26-06-2016 (26-06-2016, 09:00 AM)bashbarnard Wrote: Sounds like the fan unit its self. Would that cause the A/C button to not work?! RE: Peugeot 206 fan & A/C dead... - Piggy - 26-06-2016 So... With the fan unplugged I get 3.57volts across the two supply pins on settings 1-4. With the A/C button pressed I get 0.57volts on settings 1-4 With the fan plugged in I get 0 volts on all settings. All fuses tested out fine. RE: Peugeot 206 fan & A/C dead... - Piggy - 26-06-2016 Supply to the small section of fuses on the fuseboard that AC and fan are on isnt supply 12v and the 3.57/.57 is a feedback. (206 fuseboard is split) Ignition barrel getting full 12v supply on both lines... But ignition barrel not givint out the 12v needed... So guess this barrel is dead for sure |
