Threads: 448
51
ooking at getting something different than clones for the Rallye
What's the maximum width you can run without arch work? I'm looking at 8j but they are incorrect offset and will need spacers :/
Threads: 26
Given 6 thank(s) in 6 post(s)
Depends how low, id 9" on the back of my 306 but would rub if you were too low.
Threads: 448
51
I'm pretty low on the rear say around 80mm, I think 8j would be good. But I don't want to have to mess around with arch work
Threads: 202
58
8j et0 will go on the rear.. Just. You'll need arch work on the front I'd have thought.
I got 6.5j on et-2 and had to do arch work front and rear and its only 30/40mm drop
Threads: 448
51
I'm looking at 15 x 7 et30
So will need 10-15mm spacers to fit correct, will need arch work?
