29-09-2014, 09:53 PM
		I know this has probably been covered before. Is there anything needed to fit 205 speedlines to my '6'? Spacers? Wheel bolts? Etc. Cheers
					205 speedlines
		29-09-2014, 09:56 PM
		Bolts straight on with old style flat bolts, weights may catch on the callipers tho. them balanced with weights on the inside only
		30-09-2014, 07:51 PM
		will be fine as long as your beam isn't cambered, could do with 5mm spacers on the back but i never ran them . . .whhel weights sometimes catch for about 5mins then they don't after being worn down . .
		30-09-2014, 08:00 PM
		I ran them on two 306s fine. Nothing needed you need the bolts though. I just so happen to have a set...
On a break from 306oc for personal reasons. If anyone needs or wants me most of you have my number and or facebook messenger Thanks for the good times guys n gals. I might be back. Who knows.
		30-09-2014, 09:44 PM
		What's the difference between the bolts for my clones and the bolts needed for speedlines?
		30-09-2014, 10:57 PM
	 (30-09-2014, 09:44 PM)willJspears Wrote: What's the difference between the bolts for my clones and the bolts needed for None mate, they're the same
		01-10-2014, 07:29 AM
		Righto, cheers
