205 speedlines - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: 205 speedlines (/showthread.php?tid=26914) |
205 speedlines - willJspears - 29-09-2014 I know this has probably been covered before. Is there anything needed to fit 205 speedlines to my '6'? Spacers? Wheel bolts? Etc. Cheers RE: 205 speedlines - Daniel306 - 29-09-2014 Bolts straight on with old style flat bolts, weights may catch on the callipers tho. them balanced with weights on the inside only RE: 205 speedlines - Mattcheese31 - 30-09-2014 will be fine as long as your beam isn't cambered, could do with 5mm spacers on the back but i never ran them . . .whhel weights sometimes catch for about 5mins then they don't after being worn down . . RE: 205 speedlines - bashbarnard - 30-09-2014 I ran them on two 306s fine. Nothing needed you need the bolts though. I just so happen to have a set... RE: 205 speedlines - willJspears - 30-09-2014 What's the difference between the bolts for my clones and the bolts needed for speedlines? RE: 205 speedlines - Mattcheese31 - 30-09-2014 (30-09-2014, 09:44 PM)willJspears Wrote: What's the difference between the bolts for my clones and the bolts needed for None mate, they're the same RE: 205 speedlines - willJspears - 01-10-2014 Righto, cheers |
