Rear axle dummy shock question
Basically I'm in the process of rebuilding a rear beam for mine ,off the car and would like to know what length of dummy shock I need for a 40mm drop. Hole to hole length that is. This way I can mig one up at work bolt it on when its off the car for it to be set before fitting the new beam.
Also if anyone has done this for 50mm I'd like to know that also Wink
Should find the correct way of figuring this out and get like a chart up help everyone
Id also like to know both sizes. I have rear beam sat there that ill eventually rebuild.
I did a thread on this.
Something like
"could be useful for other members"
In suspension section
[Image: av5ym8.jpg]
  Rear stub axle sizes weka 2 4,106 26-04-2019, 06:18 PM
Last Post: weka
  Rear shock bushes Tidoh2016 2 2,862 12-05-2018, 09:38 AM
Last Post: pug306driver
  rear axle joe67 4 5,170 25-04-2018, 08:38 PM
Last Post: carlukepeugeot
