Another XUD
#31
Yeah, straight swap.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
#32
But only the pump and the injectors,right?
#33
What do you mean? The older full manual pump will go straight on, along with the injectors. Although you can use your current injectors.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
#34
And what about the smart injector?
#35
you mean the one with the wire? If so that will be fine just cut the wire off, its not needed. I have a 406 XUD in my 306 and I'm running a manual pump with the original injectors.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
#36
leave the injector etc in and get ppo then you really play with the advance springs/ip.
#37
what is ppo?
#38
Peugeot planet, its a diagnostic interface that will let read live data from the engine ecu like rpm/advance/tps, most go by ear with advance/dynamic advance.
#39
Thanks ;]
#40
Another question:
Whant nozzles I must use?...from 2.1 maybe? Smile
