GTI6 cylinder head
GTI6 cylinder head
I have a cylinder head that needs a skim!
i understand the head new is 137mm +-0.05 between the cam ladders
the maximum safe skim is to 136.8mm +-0.05 which = 0.2 of materiel can be removed
the head i have is already skimmed to 136.6mm
is this head toast or is there any options of saving it
seems a shame to scrap a head
GTI6 Info
my head was fully rebuilt and then a local skimmer ruined it by taking too much off :/
Could you use a marginally thicker head gasket to account for the extra skimming on the head?
std J4RS Metal head gasket from pug is 1.2mm 0209 Z2
J4R lists but are Fibre
1.2mm 0209 N6
1.4mm 0209 T9
the 1.4 will only bring a max safe skim back to std hight
i havent had it skimmed yet and its passed safe skim
GTI6 Info
Not sure a local garage in your country have the made to order gasket or not ?
In my country I can order the made to order metal head gasket for many kind of engine, Like a 1JZ-GTE, 2JZ-GTE that is very popular for modification in my country.
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
[Image: 150521115952.jpg]
Just use a thicker head gasket, no need to scrap the head.
Cometic makes gaskets made to order in whichever thickness you need.
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
I got a head lying around... just in case....
nice hint of a sale thread on your third post Tongue
but i think i have enough engines here already of the RS type Wink
GTI6 Info
Skim it some more, then stack two gaskets on top. If it's works out perfect then harrah! if not then it's the start of a low boost project
[Image: mcetg0.png]
Ferriday engineering are good for this kind of stuff. Have a word and see what they think
  Cylinder head faced 0.33mm removed lpr1981 3 2,678 16-05-2015, 09:57 PM
Last Post: miles
  Tube found in intake port of cylinder head lpr1981 23 11,270 19-04-2015, 11:11 PM
Last Post: welshpug
  Cylinder head rebuilt, but now sounds like a diesel, please help! rj.stead 6 3,504 14-12-2014, 12:17 PM
Last Post: Dum-Dum
