Threads: 55
Car Model/Spec: 306
I'm thinking of putting phase 3 headlights in my phase 2. After looking at a few threads I've gathered that the headlight adjuster motors are different. Does this mean I have to take the adjuster off my ph2 light and put them onto the ph3 ones? If so how hard is this..
Also due to the phase 3 lights using H7 bulbs will the full beam work simultaneously with the dipped beam? or will I need a phase 3 stalk as someone has briefly touched upon this on a different forum but not gave much info.
Threads: 151
14
Car Model/Spec: 306 D-turbo
I think if you use your current stalk it will just put full beam on but if you get a ph3 stalk when you put full beam on dipped beam stays on too someone will correct me if I'm wrong
The adjusters just twist out
Team Doesn't own a 306
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
The adjusters are simple enough to swap over from memory they twist off the headlight and then pop out of the reflector - be careful though I snapped on of mine pulling it out
If you want the main and dipped on at the same time you'll need a twin optic stalk some ph2s came with them probably on the higher specced stuff gtis and the like
Threads: 55
Car Model/Spec: 306
Ah sweet, how big of a job is it to change stalks? I'll try with current stalk first if this fails chances are ill get a phase 3 twin optic stalk as I want both dipped and full beam to work simultaneously
Threads: 164
25
If your stalk is twin optic then it will bring both lights on on your ph2 lights aswell.
Changing the stalk is easy, 3 T20 torx screws to take off the steering column surround , unplug the stalk, and there are 2 torx screws holding the stalk in (either t10 or t15 not sure which)
Threads: 55
Car Model/Spec: 306
Lights are now installed still using my old stalk until i find a twin optic one cheap enough.. Just wondering do phase 3 306's have the horn on the stalk like phase 2's?
