Ph3 headlights in ph2 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Ph3 headlights in ph2 (/showthread.php?tid=22455) |
Ph3 headlights in ph2 - Moh - 22-03-2014 I'm thinking of putting phase 3 headlights in my phase 2. After looking at a few threads I've gathered that the headlight adjuster motors are different. Does this mean I have to take the adjuster off my ph2 light and put them onto the ph3 ones? If so how hard is this.. Also due to the phase 3 lights using H7 bulbs will the full beam work simultaneously with the dipped beam? or will I need a phase 3 stalk as someone has briefly touched upon this on a different forum but not gave much info. RE: Ph3 headlights in ph2 - Danny2009 - 22-03-2014 I think if you use your current stalk it will just put full beam on but if you get a ph3 stalk when you put full beam on dipped beam stays on too someone will correct me if I'm wrong The adjusters just twist out Ph3 headlights in ph2 - rocker8742 - 22-03-2014 The adjusters are simple enough to swap over from memory they twist off the headlight and then pop out of the reflector - be careful though I snapped on of mine pulling it out If you want the main and dipped on at the same time you'll need a twin optic stalk some ph2s came with them probably on the higher specced stuff gtis and the like RE: Ph3 headlights in ph2 - Moh - 22-03-2014 Ah sweet, how big of a job is it to change stalks? I'll try with current stalk first if this fails chances are ill get a phase 3 twin optic stalk as I want both dipped and full beam to work simultaneously Ph3 headlights in ph2 - rocker8742 - 23-03-2014 If your stalk is twin optic then it will bring both lights on on your ph2 lights aswell. Changing the stalk is easy, 3 T20 torx screws to take off the steering column surround , unplug the stalk, and there are 2 torx screws holding the stalk in (either t10 or t15 not sure which) RE: Ph3 headlights in ph2 - Moh - 23-03-2014 Seems easy enough thanks bud
RE: Ph3 headlights in ph2 - Moh - 07-04-2014 Lights are now installed still using my old stalk until i find a twin optic one cheap enough.. Just wondering do phase 3 306's have the horn on the stalk like phase 2's? RE: Ph3 headlights in ph2 - WiNgNuTz - 07-04-2014 Yes, they do.
RE: Ph3 headlights in ph2 - Piggy - 07-04-2014 See my thread guide on how to make your single optic stalk into a twin optic ![]() Alternatively PM me as you can have my twin optic stalk for £5 plus postage
