Major boost leak - checked usual culprits
Was driving enthusiatically last week, and while on full boost @3k ish rpm (~25/30psi in 3rd) i was greeted by a sound resembling a burst in a pipe. Was like a burst of pressure being released 'ppsshhh'
Now, when i plant my foot, it makes a noise that i can only describe as.. errr.. someone moaning.. 'nooooooo' in a shrill high pitched noise in a geordie accent lol :roll: , only as it approaches 15psi. Up until then at light throttle it is fine - no noise.
It's not the turbo. Next to no play, either radial or axial float.
It's not the D seal before all the eager beavers chime in.
I'm thinking it COULD be the inlet manifold gasket blowing?
It COULD also be (most likely?) a split in the turbo - intercooler pipe? As the noise it makes sounds like air reverbing through an opening on full boost.
Any opinions please?
Cheers.
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
if its that bad it should be easy to spot although you say it happened at peak boost id guess its popped off a hose?
have a look around the system, might very well be the turbo-ic pipe has popped off the turbo
No, thats the first thing i checked. It's still building boost and leaking it out simultaneously so i'm thinking it's down to a split in the pipe. Hard to check without taking pipe out as it only appears to leak, and hence make the noise, under boost, above 10/15psi :|
Before pulling the pipe i just wanted to see if a leaking gasket would give similiar problems?
I'd say the pipe straight off the turbo has a split happened to me it will open the split more on boost due to the pressure.
Bye Bye D-Turbo
As everyone else has said, its unlikely to be the manifold gasket if its making that sort of noise (although the description of the noise made me laugh lol ) as said, its most likely to be either a split hose from the turbo or it has pushed the hose off the turbo as mine has done this a few times in the past!
I would check that the hose is fully on the turbo and if your sure that it is then I would remove it and check for splits Smile
Team Orange Engine Bay
mark_airey Wrote:As everyone else has said, its unlikely to be the manifold gasket if its making that sort of noise (although the description of the noise made me laugh lol )
am i the only one who also made the noises in my head, then changes the tone as reading along further into the sentence lol
but as everyone else said regarding the boost leak - also, keep the turbo/pipes clean where you're tightening them on - oily pipe are not good and will only encourage more slips.
ginge191 Wrote:am i the only one who also made the noises in my head, then changes the tone as reading along further into the sentence lol
Nah your not, I did too! lol
Sounds like you may have hit the cast of geordie shore and got one lodged under there.
306 HDI, soon to be XUD
haha! bit of received pronunciation should drive 'em out!
Had a ticking injector so i gave it some to clear it and can only assume i've now made the suspected split bigger as now it no longer makes the noise (thank fk! was driving down oap pedestrian numbers) rules out gasket, although i'm sure fumes are getting through from exh mani..
will take off pipe and check it out, cheers guys! Smile
  Major fuel pump problems, air leak, head gasket? Dantheman1312 2 4,355 22-08-2016, 09:57 AM
Last Post: r3k1355
  boost leak ? Motatalk 3 3,102 19-06-2015, 07:46 AM
Last Post: Dave
  New car, major problems jack_o 26 19,888 12-09-2014, 09:58 AM
Last Post: mr_fish
