09-01-2014, 11:54 PM
what do I need to change my standard dturbo 240mm to 266mm
266mm upgrade
09-01-2014, 11:56 PM
(This post was last modified: 09-01-2014, 11:57 PM by underground375.)
Callipers, discs and pads. Got the lot for £60
10-01-2014, 12:01 AM
I have two set ups here, both 266 one I want to keep complete.
Got a set of calipers that came of the last car I was breaking just sat here yours for £20 posted Via Parcelforcre 24H Chris
(This post was last modified: 10-01-2014, 12:02 AM by underground375.)
Yeah If your looking for just callipers send me a pm
Giving it away ay u chris?
10-01-2014, 12:03 AM
As said you will need discs and pads that are for the caliper. Also 1 note when fitting clean the threads in the hubs for the carrier bolts as the brake carrier for the 266 calipers is a bit thin so the bolts need to go further through.
Also standard d Turbo brakes are 247mm
10-01-2014, 03:09 PM
get gti6 brakes instead. probably cost you the same. Theyre all cheap now.
