Threads: 96
7
Car Model/Spec: 306 tractor
Has anyone got pictures or an exploded diagram of the std airbox cold feed etc as I'm thinking about what parts/work is required to fit this to my XUD.
The std XUD induction restricts flow and a cone filter causes the car to be asthmatic and affects drivability, so I'm thinking that fitting a HDI airbox will make it flow better but not make it asthmatic like a cone filter ????
Ideas/suggestions...
Threads: 92
43
Service box
Threads: 151
14
Car Model/Spec: 306 D-turbo
de filter
/thread
Team Doesn't own a 306
Threads: 96
7
(22-09-2013, 07:57 PM)Connor Wrote: Service box
Is if free, if so where can I get it?
Threads: 177
Iv also been planing this for a while, let us know how you get on
Threads: 96
7
(22-09-2013, 08:22 PM)Danny2009 Wrote: de filter
/thread
Ha ha no thanks Danny. I have fitted a cone to my car and a) it sounds broken & shit and b) I've noticed it's very asthmatic in its performance whereas enclosed induction gave it more torque for the fuel delivery (not needing to keep pressing the right pedal). I'm on a stage 1 mild tune so probably very weak mixture now I'm on open filter
Just need to set up a good unrestricted enclosed induction
Threads: 129
11
How does a cone filter make it feel asthmatic?
IMO I bet you couldn't really notice the difference to what filter you fit on an XUD with a stage 1/2.
Stage 2 XUD Sedan
Threads: 122
9
(22-09-2013, 09:07 PM)strictly_derv Wrote: How does a cone filter make it feel asthmatic?
This ↑↑↑
Apart from running defiltered you get a slightly quicker spool time and epic sounds
Threads: 96
7
I can feel a difference with the unrestricted air filter, I'll try and explain...
I know a certain hill very well, I usually hit it at 60 and do not add any more right pedal to get to the top: -
•std airbox doing 55 at the top
•cone filter doing 50 at the top
So fitting the cone filter makes it 5mph slower at the top of this hill but generally gives it a better throttle response and the car is smoother on to boost  . I'm on a mild tune and not upping the fuel to compensate for the extra air though the filter means the car is running weak, hence dying on hills. I can't be bothered to up the fuel on the Lucas so going to go back to enclosed enclose filter plus it sounds broken
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Another vote for defiltered. I've left my standard system in place so I can replace the rubber section connecting the plastic pipework to the turbo in winter/wet weather.
Threads: 208
60
it wont work. the bottom end will explode within 5miles !!!!
Threads: 96
7
(23-09-2013, 11:58 AM)puglove Wrote: it wont work. the bottom end will explode within 5miles !!!!
What de-filtered? I may think about what we discussed about the std airbox
Threads: 266
18
Car Model/Spec: 205 DTurbo
Just radge one in there. Can't be that hard!
Threads: 96
7
28-09-2013, 04:38 PM
(This post was last modified: 28-09-2013, 04:39 PM by devils_fuel.)
(28-09-2013, 12:08 PM)silverzx Wrote: Just radge one in there. Can't be that hard!
I am trying to measure space etc to put the original plastic DT canister with filter in, minus all the bends etc so it's a straight path to the turbo.
Or getting a hdi airbox but not costing the earth, people want silly money for them + postage
Threads: 266
18
(28-09-2013, 04:38 PM)devils_fuel Wrote: (28-09-2013, 12:08 PM)silverzx Wrote: Just radge one in there. Can't be that hard!
I'm sure you could get one from a scrappy!? One in Weston usually has a fair share of 306/406s. Doubt they'd charge a fortune!
Threads: 96
7
(28-09-2013, 11:44 PM)silverzx Wrote: (28-09-2013, 04:38 PM)devils_fuel Wrote: (28-09-2013, 12:08 PM)silverzx Wrote: Just radge one in there. Can't be that hard!
Which scrappies Trent?
Threads: 266
18
In Weston just off winter stoke road near mc Donald's, asda, wait rose etc there is two scrappies.
One you say what you want and they'll remove it and charge you X amount agreed before hand.
The others called Harrison bros, you look around then help yourself to whatever you want and then go haggle a price. It's the better one of the two IMO.
