gauge wires
gauge wires
Hi guys was looking at this guide to fitting my boost gauge
http://www.306oc.co.uk/forum/thread-2940.html
all sorted with connecting it to the intercooler etc
quick question in regards to the 3 wires i have on it
[Image: boostgauge_zps297ed128.jpg]
am i right thinking the red one can go onto the orange wire under the steering wheel in the coin tray thingy on P1 or would i need to put it on the switch wire of the stereo?
ground is located in the drivers footwell
and lastly one that isnt mentioned on the guide
where would i put the purple wire which is supposed to go onto my "light dimmer"? and where is it located
thanks guys
Find a switched live and connect the red to it.
Purple can also go to where you connect the red wire if you dont mind none been able to adjust the brightness.
sound man Big Grin
and ill just pop them both on the switched live then brightness isnt a issue as long as it works!
yeah all sorted joined the purple/red together just need to extend it now and scotchlok it into the headunit switched live
switched live on the 306 is the white one i believe?? and pink is permanent (p1)
Yeah white is switched iirc.
Cool man thanks for your help Smile
  drivers door loom wires pug306driver 3 1,549 27-11-2016, 06:29 PM
Last Post: BiG K
Photo radio wires rosylyn 3 1,421 31-03-2015, 11:55 AM
Last Post: Toms306
  where do the wires for the sidelights run Hamish 0 965 09-06-2014, 07:20 PM
Last Post: Hamish
