Bleeding Brakes
Bleeding Brakes
I went to bleed brakes on my berlingo i just bought and its air locked pretty bad, whats the correct pattern to bleed brakes on these vans?
Start furthest away from the master cylinder and work you way towards the nearest.
I'm not sure if the berlingo is the same, but on the 306 it goes:
N/S/R-->
O/S/R-->
N/S/F-->
O/S/F
Just double check the position of your master cylinder Smile
Will be the same, does it have abs??
you go diagonal on non-abs . . . .nsr-osf-osr-nsf . . Smile
ABS makes no difference.
All braking systems work in a diagonal.
(23-06-2013, 03:59 PM)Piggy Wrote: ABS makes no difference.
did i say different? . .Wink . . .lol tbf all mine have been no abs . .Big Grin
still could not get pressure in the system, no fluid coming out, changed m/c and still the same,
my method of bleeding is using a clear tube connected to a container filled with fluid with an assistant pumping
never had problems bleeding before any ideas?
It could make the bleeding a lot easier, as if it is a PH3, or a late PH2 with EBD, you could do single person bleeding using Peugeot Planet. It uses the EBD pump to bleed the system for you.
Bazinga.
no abs
  Bleeding Brakes With Peugeot Planet Tom85 3 3,099 22-06-2017, 08:08 PM
Last Post: Tom85
  Help with brake bleeding Iaitoo 18 6,614 10-06-2016, 06:06 PM
Last Post: Poodle
  Bleeding abs pump. bashbarnard 14 7,806 24-05-2015, 06:48 PM
Last Post: Toms306
