Anyone fit engines?
Anyone fit engines?
Ok, so I replaced the fuel sender unit and it started. My happiness was short lived when I could still hear a very loud tapping from the engine. Just weighing up my options . I may break it but not many good panels. Does anyone on here fit engines? As my Talent doesn't extend to that, I know it's not rocket science but I just don't have the patience to do so. It's a 306 Hdi estate w reg. if so a price would be great so I could way up my options. Thank you
where are you?
sure its engine tap?
http://www.krisb.co.uk/
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
^^^ as above
Or it really Isnt terribly hard to do yourself. Heater matrix hoses and drive shafts are the worst bit.
Hdi engine is a piece of piddle to change! Grab an engine crane and a handful of tools and an unexpected passer by and you'll have it done in no time.
[Image: ForumSignature.jpg]
Would be alot cheaper for you to just spend a weekend doing it.
Located in Shrewsbury. I ran the engine with hardly any oil reading. I have put a litre and a half in and still so noisy! Sound is worse when you put your head in the driver wheel arch. Just fed up of bloody thing. Car has only done 100000 so pretty low mileage. Just don't want to do it myself or will just put for sale and buy another daily.
How far you willing to drive as I have a hdi engine I'm
Currently breaking so we could negotiate something
drivers side ??? sure its not the crank pulley broken up ---they make an horrendous noise sometimes ??? get a light and check with engine running that the outer rim of the pulley isnt flapping all over the place .
defo sounds like crank pulley!
Good to meet you the other day Smile If its crank pulley I have a solid one if you are interested Wink
Ok thanks guys. Will try put it in ramps tomorrow and have a look. Is it a expensive job? Yes you too lee
How much for the solid pulley lee?
It isnt an expensive job, if you really cant cope with doing it yourself.
  What diesel engines do you rate? tuttyboy84 57 26,913 12-04-2016, 03:06 AM
Last Post: Dave
  Painting Engines Eeyore 14 7,460 14-05-2015, 06:12 PM
Last Post: Seb_Ryan
  What engines would you say are "bad" lolsteve 33 21,806 27-05-2013, 09:36 PM
Last Post: THE_Liam
