Threads: 252
7
I have a set of single optic phase 1 lights to go on but the phase 2 has different plugs. If I get a set of twin optic lights do there plug into the standard plugs or do I need the connector and some abit of the wiring to be able to join them in?
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 92
43
You'll probably need to swap the plug, afaik the ph2/3 has a multiplug and the ph1 plugs are individual. Also what are you doing about the slam panel? You gonna bodge the lights on or you swapping it?
Threads: 252
7
Swapping it putting a full Phase 1 front on bonnet bumper ect. Ye its all one plug on the phase 2 so if I break them open and take the wiring out I can plug the original multiplug in then wire the phase 1 bulb holder to the loom so I can just unplug it if I ever fit phase 2/3 lights again?
Sedan Project
Blaze 1.6 Dead
