injector socket
injector socket
Just wondering what size socket(s) will be needed to convert from lucas to bosch?
Cheers,
Phil
No smoke, No poke!
27mm deep
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Will just a normal deep socket do the job? Or do i need an actaul socket for injectors?
No smoke, No poke!
A normal deep 27mm sockets fine
Team Doesn't own a 306
That will do, cheers
No smoke, No poke!
Heard the halfords ones arent deep enough tho?
Ahh balls typical i have halfords ones haha any particular make then?
No smoke, No poke!
I used a halfords one and it was fine.
Bye Bye D-Turbo
It depends - a big 27mm generally will fit, but some have casting marks which won't clear the leak off nipples.
Halfords ones it depends who they're using to make the sockets these days, they used to fit, but I've a suspicion I've heard someone say they bought one and it didn't fit - so essentially - it's a stab in the dark. If it doesn't fit, you'll just have to take it back!
27mm spanner
I use a 27mm halfords socket. I needed to hit the socket on the lucas injectors and it f*cked the thread on the injector line bosch injectors it's fine though
27mm injector socket Wink . Cheap on Ebay.
draper do specific 27mm injector sockets.
I bought a 27mm deep socket and an injector socket when I took some off. Injector one worked fine and returned the unused one.
I cut a socket in half and welded a bit of handrail tube between it
I had a Draper one too, was cheap and does the job.
http://www.halfords.com/motoring/garage-...ocket-27mm
Halfords 27mm injector socket Smile
(12-08-2014, 06:29 PM)welshpug Wrote: draper do specific 27mm injector sockets.
as do laser tools,
local motorfactors, wont be the cheapest in the world but it works a treat!
/Toseland
This. You won't go wrong.
Don't do halfrauds.
Will order a draper one then Smile
Cheers!
No smoke, No poke!
