Rear beam Part no's
Rear beam Part no's
After 3 weeks on and off, 2 cans of WD40, 1 hot air gun, a lump hammer, 2 screwdrivers, and countless expletives I have managed to strip down a '6 beam.
Would someome be able to help me with finding the following part numbers at all?
1 x TB threaded end cap
2 x Shouldered bolts that sit behind above cap and into the end of TB's
1 x Nylon Torx c/sink bolt
1 x Seal & bearing kit ( are the ebay kits @ £20 per side ok )
1 x TB end plate
2 x Handbrake cables
As you can tell - quite a b*****d to strip but tube and shafts look ok.
Thanks all Nick
Current - 306 ph1 xrdt - 323 estoril. History - Legacy Outback - Impreza Wagon - BMW 530 - Golf GTI mk2 - Escort TD - Audi 80 coupe - Astra GTE - Escort XR3
Project : http://306oc.co.uk/forum/thread-23625.html
(30-07-2014, 11:50 AM)nick000 Wrote: After 3 weeks on and off, 2 cans of WD40, 1 hot air gun, a lump hammer, 2 screwdrivers, and countless expletives I have managed to strip down a '6 beam.
1 x TB end plate
Thanks all Nick
Can anyone help with where I can find part no's for tb end plate, & end caps?
thanks
servicebox, desler will be cheapest for most of that and ofte the sole source
  Rear beam ...the good and the bad Mighty306 35 30,448 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,305 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 15,318 18-03-2019, 03:40 PM
Last Post: MOK
