08-04-2014, 10:31 PM
In need of drivers side wheel hub must be 16mm, abs and close to Nottingham as possible.
![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
Wanted: Wheel hub
09-04-2014, 06:12 AM
if the 1.6 hubs are the same I have one altho not 100% on ball joint size.
09-04-2014, 08:10 AM
Can you measure ball joint with vernier gauge? Needs to be abs too
09-04-2014, 10:28 AM
Got a pair of 16mm hubs don't think they are abs ones thougj
09-04-2014, 10:50 AM
i have some with abs will chuck them in with beam if u want them kent
09-04-2014, 12:12 PM
09-04-2014, 12:13 PM
Just get an 18mm with the corresponding ball joint
09-04-2014, 06:04 PM
(09-04-2014, 12:13 PM)Andy! Wrote: Just get an 18mm with the corresponding ball joint I would but I have brand new ball joints on the car. Ive sorted some from teddy.
10-04-2014, 08:37 PM
I have a pair of 18mm .
bearings in working order if your desperate |
